Oh it started out so easy......
Old Mar 28, 2010 | 10:54 PM
johnnyx's Avatar
CLEAN THE CARBS!!!!!!!!
I've also got a new in box integrated tail light for that bike if you want it. They're hard to come by. I'd let it got for $75 - PM me if you're interested.
M240Bravo's Avatar
Originally Posted by Kuroshio
Hang on a tick yall. His r/r has obviously been replaced already. The damaged connector may be leftover from when the original went out. I've got the same burnt pin on mine but testing the r/r comes back good and I don't have a charging problem. So I'm pretty sure mine was replaced in the past.
If you haven't had any charging issues, you may not need a new one. Grab the service manual and a voltmeter. There's a diagnostic routine in it that'll let you check the charging system. If mine ever went out I have plans to go aftermarket new. Electrosport sells direct plugin aftermarket r/r for all our bikes. Along with replacement OEM connectors
Well the only really reason I found it was because the bike won't start after I replaced the battery after sitting all winter.
Old Mar 28, 2010 | 10:55 PM
johnnyx's Avatar
That's almost certainly a carburetor issue. Is it cranking? Do you get spark?
Old Mar 28, 2010 | 10:56 PM
M240Bravo's Avatar
LOL How do I clean the carbs? Whats that tail light look like and why is it better then my stock one?
Old Mar 28, 2010 | 10:58 PM
Kuroshio's Avatar
WOW thanks. I'll be shopping a lot for the next month until I get the bike on the road.
Anything else you think I should do while I have the bike broken down?
Dude, test before buying. It's better to pay $8.95 + shipping for a new r/r connector than $59.95 + shipping for one you don't need.
Hit up Radio Shack / Pepboys / Autozone and get some female quick connects. Crimp them on the wires and hook up your existing r/r. Then test it with the voltmeter.
Old Mar 28, 2010 | 10:59 PM
M240Bravo's Avatar
If I keep it on the battery charger it will start right up. Its like it won't keep a charge.
Old Mar 29, 2010 | 12:01 AM
spicymeowmix's Avatar
Official Welcome Crew Spicy Cat
I would follow Kuro's advice.
Old Mar 29, 2010 | 01:46 PM
M240Bravo's Avatar
Ya I'm going to check it before I buy a new one.
Old Mar 29, 2010 | 03:01 PM
Kuroshio's Avatar
One more thing: bike doesn't charge the battery at idle. You need to get the rpms up to 3.2k-4k before the stator produces any significant voltage. If you're saying it wont hold a charge idling in the garage, that's normal
Old Mar 29, 2010 | 04:53 PM
M240Bravo's Avatar
thanks. Man I'm a noob at bikes. LOL
