Oh it started out so easy......
Old Mar 28, 2010 | 10:02 PM
M240Bravo's Avatar
Default Oh it started out so easy......
Well I was just going to change the oil. Then I started to change the spark plugs. Now I'm fixing wiring, and flushing all the fluids.
Also any one know what this black box thing is?
Old Mar 28, 2010 | 10:10 PM
dyracuse's Avatar
regulator rectifier I believe
Old Mar 28, 2010 | 10:13 PM
dmcb2120's Avatar
as he said !!! Time for a new one
Old Mar 28, 2010 | 10:15 PM
millertyme's Avatar
lots of threads about this issue. so now you will add a new r/r to the list of things to do.
better to find it in the garage, than 400 miles from home.
Old Mar 28, 2010 | 10:20 PM
M240Bravo's Avatar
Thanks guys. So can I just pick one up at the auto parts store or bike store?
Also is there like a new guy thread? I have some other things to ask.
What spark plugs to get.
what air filter to get.
How to flush my brake fluid.
Old Mar 28, 2010 | 10:23 PM
millertyme's Avatar
i would search the classifieds here, or you can check ebay. most bike dealers should be able to get the aftermarket ones quick quickly i would suspect.
Old Mar 28, 2010 | 10:36 PM
spicymeowmix's Avatar
Official Welcome Crew Spicy Cat
it's notorious for going out, so no worries there
http://cgi.ebay.com/ebaymotors/91-92...Q5fAccessories
but
there are many kids who use yamaha R6 rectifiers,
which work really well.
side note:
might want to invest in an APE Cam Chain tensioner as well
down the road of course... there's a walkthrough of one in my sig.
the f3s have r/r problems and cct problems.
Old Mar 28, 2010 | 10:44 PM
Kuroshio's Avatar
Hang on a tick yall. His r/r has obviously been replaced already. The damaged connector may be leftover from when the original went out. I've got the same burnt pin on mine but testing the r/r comes back good and I don't have a charging problem. So I'm pretty sure mine was replaced in the past.
If you haven't had any charging issues, you may not need a new one. Grab the service manual and a voltmeter. There's a diagnostic routine in it that'll let you check the charging system. If mine ever went out I have plans to go aftermarket new. Electrosport sells direct plugin aftermarket r/r for all our bikes. Along with replacement OEM connectors
Old Mar 28, 2010 | 10:48 PM
johnnyx's Avatar
Old Mar 28, 2010 | 10:50 PM
M240Bravo's Avatar
but
side note:
WOW thanks. I'll be shopping a lot for the next month until I get the bike on the road.
Anything else you think I should do while I have the bike broken down?
