Now that I pulled head off
Old 07-26-2013, 10:10 PM
kikoh's Avatar
Default Valves wont close :(
Now that I was exited, because I received my shim kit. I go farther back, then when I started. when I installed the cams and timing chain, i rotated the timing mark couple of times but i notice a clicking noise coming from the exhaust valves . I pulled the cams back out again and notice the buckets not going all the way up, and the spring looks like its compressed. i just hope i dont bent the valvesName:  IMAG0765.jpg
Old 07-27-2013, 10:00 AM
kikoh's Avatar
I tried removing the buckets, with the magnet but failed. Could they be stuck?
Old 07-30-2013, 10:07 PM
kikoh's Avatar
I removed the head, and pressed the valves close with my thumb. what could caused them to stay open?
spring?
Old 07-30-2013, 10:16 PM
kikoh's Avatar
Default Now that I pulled head off
Now that I pulled the head off to check 3 valves that wouldn't close.
what should I check or replace . Should I resurface the head?
Old 07-31-2013, 02:56 PM
Well what was the result of your check ? You pulled the head off because the valves weren't closing. Did you find out why they're not closing ?
Old 08-01-2013, 04:35 PM
kikoh's Avatar
If I push down the valves with bucket in, the valves stay open with the buckets off the valves close, also the buckets are hard to remove with a magnet, these are in the exhaust side. seems like the buckets hold the valves open. tried switching buckets from intake side and same happens. Do the springs expand?
Old 08-02-2013, 10:49 PM
Something is seriously wrong here. You should not be able to push the valve down by hand at all. The amount of spring pressure holding those valves closed is immense. Look closely at the photo below. The bucket is off and you can see the top of the valve stem. The top of the valve stem is surrounded at the top by what's called valve spring keepers. They're 2 split halves of a sleeve that hold the top of the valve and the valve spring is held in place by them. It's item #10 and Honda calls them "Cotter, Valve".
__Z__
02-07-2011 02:06 PM
jstew600
08-08-2008 07:50 PM
volcomrr
09-29-2007 05:03 PM
c0ldf1ame
03-08-2007 10:54 PM
Turnin20s
05-22-2006 10:15 PM
Quick Reply: Now that I pulled head off
