Not starting
Old Apr 17, 2014 | 03:19 PM
LedFloyd900's Avatar
Default Not starting
I have a '95 600F3 I just put an F2 motor on (the motor is dang near brand new) and while I had it all apart I replaced the battery (old one had a bad cell), so it started perfectly fine, and right before I put it all back together I started it again just to make sure it would. After I put it all back together I sprayed it off and washed it with some wash & wax, but now it won't start!! It has been a couple days now and it still won't start. The starter engages and I can hear it cranking over but it just won't start. Please help, I haven't gotten to ride it since November and I'm super anxious!! Thanks for any advice
Old Apr 18, 2014 | 12:23 AM
josiahafelix's Avatar
Is it turning over as fast as usual or does it sound like the battery is dying? I would check the voltage, probably have a bad ground somewhere
Old Apr 18, 2014 | 11:24 AM
It turns over real fast, i mean perfectly. How would i find a bad ground?
Old Apr 18, 2014 | 02:37 PM
Well if its cranking over well enough then its probably not battery related, I was thinking bad ground causing the battery to drain, could be related to washing it, water on electrical connections is never good, have you tried starting fluid or anything to rule out a fuel issue?
Old Apr 18, 2014 | 10:40 PM
No I haven't, that's a good idea though. Ill let you know, I appreciate it
Old Apr 19, 2014 | 02:00 PM
Well, I tried the starting fluid...still nothing. I did find out that it's not getting a spark though. Think I need new coils?
Old Apr 19, 2014 | 03:18 PM
If it went from running fine to washing it and then not running I wouldn't image it's the coils, start combing through the electrical, double check your connectors and fuses, maybe something blew after getting wet
BlackDogIron
Sep 14, 2017 05:47 PM
Nevets
Nov 8, 2010 04:45 PM
BrokeCollarBone
Nov 24, 2009 01:24 PM
bh1
Dec 7, 2007 02:36 PM
steeper
Jun 23, 2006 02:49 PM
