Not charging when hot engine cbr600 1995
Old May 20, 2025 | 03:18 PM
600rbc's Avatar
Default Not charging when hot engine cbr600 1995
So it all started onwsy home from mot bike broke down completley dead no ignition lights etc.Traced fault to blown main 30amp fuse.So renewed it bike started up straight away and no flat battery.Since then i have been monitoring charge rate and it doesnt charge when hot tested rectifier it passed with no probs but replaced it twice as first one was faulty but still the same.Checked resistance all 3 yellow wires for stator getting 0.1 ohms also testing to ground for a short but passed.
Also tested R/W cable to rectifier and im getting battery voltage.What AC should i get out of the 3 yellow stator wires any advice i would be greatful thanks for reading.
Edit
Old May 21, 2025 | 05:10 AM
600rbc's Avatar
Upddate just measured AC voltage on 3 yellow wires coming out of stator only getting 11.9 -12.1 volts which i think is the problem.
Old May 21, 2025 | 05:38 PM
There are no specified voltage checks for the alternator only resistance, if you are only getting c.12v at the battery then your alternator / R/R is the problem.
Output should be 13-15v at 5k revs
600rbc
May 26, 2025 07:28 AM
bkubes
Sep 13, 2011 11:00 PM
falieson
Jan 21, 2010 11:52 PM
dketelsen
Dec 4, 2006 07:40 PM
greenracef3
Oct 11, 2006 10:33 AM
