Noob question
Old Aug 30, 2012 | 10:52 PM
Stukas87's Avatar
Default Noob question
I'm sure most will be like, oh wow this has been discussed million times lol but I did search three threads similar problems but still havnt had an exact awnser so. When I bought the bike in the spring I put a new battery in her. Never had problems sense ( crapy dead one was in it when I got it and had starting issues). Now lfew weeks ago it died, I charged it on my trickle charger to full. Tonight it died when I was at my buds shop, I jumped it with car battery to get it home at least but died at a stop light, rolled over and me and a fellow biker tried pushing it down hill to but the battery was just done for I think so it's sitting at taco bell for the night lol I'm still learning about bikes, so now does a bike have an alternater like a car does to keep a charge? And what exactly is a STATER? What's it do, ect. I'm guessing I just need a new battery or my buddy said you can buy w stater and and solve the issue. Does my bike have one!? 96 600f3.
Thanks for any help you guys give
Old Aug 31, 2012 | 12:45 AM
gotcbr's Avatar
You should check your charging system. See the factory service manual. While it may be the stator, more often than not - its the R/R. A bad R/R will kill a battery dead. Of course a bad battery is the first thing to check.
Old Aug 31, 2012 | 12:46 AM
RedBaron's Avatar
Do a search for R/R (regulator/rectifier), a very common problem on these bikes and there is lots of info about it on here.
Old Aug 31, 2012 | 10:29 AM
Stukas87's Avatar
Thank you sirs will do
Old Aug 31, 2012 | 06:52 PM
MadHattr059's Avatar
A stator is the bike-version of an alternator. Usually the wire coil is fixed and the end
of the crank, spins permanent magnets inside of it. It sends 3 legs of AC current to
the regulator/rectifier. The r/r's job is to first rectifiy the AC to DC and then regulate it
between 11.8-ish to 14.6-ish volts. This is sent to the battery and, in parallel,
to the rest of the bike's electrical systems.
Here's my favorite electrical/charging system, diagnostic/over-view links...
Charging System Diagnostics - Rectifier/Regulator Upgrade - Triumph Forum: Triumph Rat Motorcycle Forums
https://cbrforum.com/forum/f2-tech-9...-solved-27739/
Technical Resources - Resources for Electrical Systems on Motorcycles and ATVs - ElectroSport
Hope this helps, Ern
Mario072
Jul 29, 2011 04:57 PM
CBRockin
Dec 22, 2010 08:06 PM
S2005
Jun 11, 2010 08:59 PM
Vanandt71
Jul 29, 2009 07:40 PM
jersey8
Dec 16, 2007 11:19 AM
