Noise when in neutral
Old Jul 9, 2010 | 09:04 PM
MarkF3's Avatar
Default Noise when in neutral
My F3 is making a rattling noise when I'm in neutral and let the clutch out. If I pull the clutch in, the noise goes away. Also, the clutch handle is only active from 0% to 50% pulled in... the final 50-100% travel is pretty much dead space.
What possible adjustments should I try?
(yes, i've searched the boards some, but i'm not a very experienced mechanic, and don't know exactly what I'm looking for)
Old Jul 9, 2010 | 09:59 PM
pacemaker's Avatar
The noise is the Clutch basket, this query comes up often. No adjustment, as it's perfectly normal.
Old Jul 10, 2010 | 03:44 AM
land_warrior.rus's Avatar
Thats normal mate, done worry about it, most bike do that.
Old Jul 10, 2010 | 09:02 AM
XerxeS's Avatar
Could also be your CCT. Mine makes a full on rattle from the right side with clutch out and no rattle clutch in. Check you clutch cable as well as may be streched. Could be the clutch basket but it is unlikely unless the bike has been abused (wheelied/stunted)
Old Jul 10, 2010 | 01:26 PM
MarkF3's Avatar
Thank you all for the response. I've had the bike for 10 years and it hasn't been stunted or abused too much.
Old Jul 10, 2010 | 02:49 PM
It shouldnt matter if the clutch is engaged or disengaged for the CCT to be making noise.
Its either making noise or it doesnt.
Old Jul 10, 2010 | 03:20 PM
XerxeS's Avatar
Hmmm.. odd. just my 0.02... With mine the cct only rattled with the clutch out. Never with the clutch in... A manual cct sorted it no problem.
Old Jul 10, 2010 | 06:35 PM
Procrastinator's Avatar
My clutch pack does the same deal. Not a problem.
Old Jul 11, 2010 | 05:22 PM
thatsarachik's Avatar
I asked this not too long ago because mine does the same thing. My boyfriend agrees that it's the clutch basket and nothing to worry about. The way he explained it makes sense, and I tend to take his advice over anyone else.
Old Jul 11, 2010 | 06:31 PM
96CBRJimmy's Avatar
i haven't changed my CCT just yet but I'm pretty sure this will sort my problem too based on the location of the noise.
SevenNoOni
Sep 25, 2012 10:24 AM
S.keen
F2 Tech
Aug 19, 2010 09:18 PM
TennesseeCBRF2
Aug 27, 2008 11:17 AM
chriso
May 14, 2008 05:46 AM
de goose man
Mar 28, 2007 01:32 PM
