Noise in neutral
Old Aug 23, 2006 | 08:40 PM
TennesseeCBRF2's Avatar
Default Noise in neutral
I have a strange noise when my bike is in neutral, but it only happens when I don't have the clutch pulled in. With the lever out it sounds like a grinding, vibrating kind of noise. Also, in 1st and 2nd at low RPMs there is a knocking or popping sound coming from the front of the bike. I know it's coming from the motor because I leaned down to listen and it was obvious. This question was posted by someone in the 929 forum, but there were 2 replies: normal noise and serious problem. Has anyone else had this problem before with an F2)? I am scared to ride now. Any help would be great!
Old Aug 23, 2006 | 09:43 PM
racer212's Avatar
Default RE: Noise in neutral
When in doubt, go to the dealer. Hard to figure out online... is your chain clean? They can make a lot of popping noise which you might only be able to hear at low speed and rpm. Same for wheel bearings.
Old Aug 24, 2006 | 12:14 AM
richterat83's Avatar
I am going to guess cam chain tensioner. Makes alot of noise on the F2's until you've warmed up. Common problem with F2s.
Tylor
Old Aug 24, 2006 | 01:21 AM
trance92071's Avatar
my f2 used to make the same sound but it has gone away now. I was thinking it was the clutch and the way i was shifting but now it does not do it anymore. Since then i have lubed the chain and changed the oil and also learned to **** better :P but i don't know what the problem was but it has gone away
Old Aug 24, 2006 | 07:48 PM
Well, I cleaned and lubed my chain today and the popping noise in 1st and 2nd went away. I still have that grinding sound in neutral though. I am thinking of taking the clutch apart to look at the plates. Do you guys think it's wise to buy a used clutch assembly? There's one on eBay right now: Any thoughts? I would post a link to it, but I don't know how. If you want to check it out just search for cbr600 assembly and it's easy to find from there. I figure it might be worth a try for $35. thanks in advance for replies
Old Aug 24, 2006 | 10:42 PM
MT Wallet's Avatar
yes maybe CCT?
Old Aug 26, 2006 | 12:40 AM
jasonty's Avatar
My bike does the same thing. In neutral, with the clutch in, no noise, but with the clutch out, i get some sort of rattling/vibrating noise from the engine compartment. This is at a dead stop. It's not my CCT, because I have an adjustable one. I think this might be either something inherrent to F2's, because my bike rides/shifts great and it has 32K miles on it. But, there could be some worn out springs in the clutch assembly. Guess I'll find out when the thing takes a crap!
Old Aug 26, 2006 | 07:10 AM
mikequinn's Avatar
The noise you can hear in the clutch is the thrust bearing common in al early CBRs & nothing to worry about. When you disengage the clutch (pull the lever) does the noise go?
The other noise from the engine could be a whole range of thing can you be more specific.
Old Dec 17, 2006 | 02:36 PM
AlpineCBR600's Avatar
Mine makes alittle sounds in N also.. Not too worrie iv heard its a common problem/question.. Mine still runs wonderful..
Old Aug 27, 2008 | 01:51 AM
UpFront's Avatar
Hey,
I've sort of been replying about this in different threads, but I also have a knocking in my engine at low rpm. It's really annoying! Anyone with answers!?!?!
Also, I have the same grinding noise when I let the bike into neutral.. super annoying as well..
