no start on fresh build
Old Feb 24, 2012 | 10:54 AM
brad horton's Avatar
Default no start on fresh build
I have just finished putting together a 98 cbr600 on a 95 frame. I have swaped everything along the way. My engine will spin with the starter, I have spark on all 4 plugs. I did not remember the order the wires to the coil went. I think I know how the spark plug wire runs(left runs 2 and 3 and right runs 1 and 4). I still don't know what leads go to what coil. I caught myself checking every possable combination but I got nothing. I am trying to start on starting fuild at the point so carbs should not be problem unless there is somthing I am missing. Please help the bike is all together all my gear just came in and it hit 80 here yesterday for the first time
Old Feb 24, 2012 | 07:22 PM
Shiffts's Avatar
Not sure which harness you're using, but on my 96 F3 the yellow/blue goes on the left (with black female connectors) and the yellow/black goes on the right (with white female connectors). Then you've only got 4 possible combinations of wiring it up. Good luck!
Old Feb 24, 2012 | 10:17 PM
Project96's Avatar
You may have spark, but it might not be at the correct time. The Yellow/Blue wire goes to the 1&4 coil. The Blue/Yellow wire goes to the 2&3 coil. They both have a common Bl/W wire that has 12 volts to it with the key on. The secondary coil wires (spark plug wires) for the left coil go to 2&3. The other 2 plug wires from the right coil go to 1&4. Hook up your fuel tank with the wires connected properly & try again.
Old Feb 26, 2012 | 06:44 PM
I did take my stater cover off. is there any way to put it on wrong? does it matter where the bl/w vs the yellow blue go one the coil?
btws roll tide (im in school at UA and his is a storm victim bike hints the new frame)
David Van Onselen
Oct 22, 2014 04:04 PM
baboex
Sep 29, 2012 09:00 PM
Honda125 358
May 14, 2011 04:47 AM
bennyhill17931
Dec 12, 2010 11:52 AM
bambam
Nov 15, 2008 10:58 AM
