No power
Old Dec 1, 2019 | 10:07 AM
Thediggsmang's Avatar
Default No power
I took the motor down on my bike so I could do a valve job on it. To do that I had to disconnect most of the electronics. Then I broke a valve cover bolt off in the head and had to fix that issue. Now the bike is back together and the issue I'm having is when I plug everything and turn the key I get power. All the lights come on, headlight comes on, brights work fine, blinkers work fine and so does the brake lights. But then I hit the starter button I hear a click and lose all power. Nothing at all. So I replace the main fuse and the power is restored and once again I push the starter button and click no power. The battery terminals are hooked up properly, the ground is hooked up, everything is run properly to the starter relay. I cant figure it out.
one thing I do find odd though is I have gobe through about 5 fuses and when I pull each fuse it looks just fine. Doesn't look blown at all. Even the brand new one look like they just came out of the package. 5 in a row.
Old Dec 1, 2019 | 07:18 PM
74demon's Avatar
Battery is low, assuming the motor turns over manually.
Old Feb 5, 2020 | 07:57 PM
Phaze212's Avatar
check your ground wire,
Kevin Quan
Apr 18, 2018 02:04 PM
STO716
Nov 13, 2011 11:17 PM
CBRPastor
Aug 23, 2010 07:17 PM
FuzzyWuzzyBear
F2 Tech
Mar 22, 2010 05:39 PM
amig
Nov 3, 2008 07:41 AM
