Need some chain advice
Old Apr 20, 2008 | 12:57 AM
ta8218's Avatar
Default Need some chain advice
Ok... so when I bought my 96 f3 it had a -1 +2 setup. The chain is endless and I assumed it was still stock. Well When I bought a new engine I had the guy throw in some good looking STOCK TOOTH COUNT sprockets too. They have very little wear, and I feel fine using them (and I'm quite **** to be honest.) Here's the trouble. This chain that is still around my swingarm is endless and does not fit the sprockets. I'm not sure what the sprockets are, but I think they are from a 98 bike. Now... the problem with the chian is not the thickness, its the fact that the chain links/teeth dont line up properly. Like... maybe 3 or 4 will slide on, then the fifth will sit high, obviously wrong chain. I really doubt that it is stock. Both of these new sprockets have the same problem with this chain and the front one is stamped JAPAN and I'm pretty positive its one form honda. So... what's wrong with this chain? How much is a new one? What do I need?
Old Apr 20, 2008 | 01:02 AM
kwong2001's Avatar
Default RE: Need some chain advice
You'll need a dremel to get the old chain off assuming you don't won't to remove your swingarm, a rear stand or some way to support the rear part of the bike in the air to remove the rear wheel, and a chain press for the master link if you use a press fitted master link. Um, chains can vary anywhere from maybe $100 or less to $170ish. Be sure to find out what size chain those sprockets are meant for i.e. 520,525,530.
Old Apr 20, 2008 | 01:08 AM
ta8218's Avatar
but... why doesnt my current one fit? its not the thickness.
and is this any good?
http://www.bikebandit.com/product/A5258554
Old Apr 20, 2008 | 10:07 AM
kwong2001's Avatar
Maybe the sprockets you were given weren't the right size?
Oh, and stick with an RK or DID chain.
Old Apr 20, 2008 | 11:18 PM
ta8218's Avatar
meh, I know thw old ones DEFINITLY werent stock and im 95% sure these are, so my bet is that old chain is weird ****. I'm takin my new rear sprocket to a bike shop to get an opinion tomorrow.
Old Apr 20, 2008 | 11:24 PM
ta8218's Avatar
http://www.bikebandit.com/product/A5078267
Is this any good? PRetty damn cheap.
Old Apr 21, 2008 | 01:25 PM
jojackson's Avatar
speaking of chains and sprockets, is your chain supposed to have room to move on the sprockets? mine move, but probably only about 3-4mm in either direction. is this how it's supposed to be?
Old Apr 21, 2008 | 07:17 PM
ta8218's Avatar
no, movement is bad
dodger79
Apr 4, 2013 08:31 AM
slightreturn
Mar 28, 2013 12:27 AM
F4iMane
May 25, 2011 08:34 PM
JetPilotMike
Apr 28, 2011 04:37 PM
whiteknight
Sep 30, 2007 12:44 AM
