Need Rim Help
Old Jan 20, 2008 | 12:05 AM
CBenRieder600's Avatar
Default Need Rim Help
So I am getting my rims powder coated so i had to get the weights, bairings and tire taken off and when i got home I noticed that this was still on the rim. The first two picts of what is still on the rim and the last pic is the other side of the rim and how I think the other side should look like. i need to know if I should take it off, powder coating gets to 400 degrees so I am afraid it might melt and I am also afraid that it might get ****ed up if it gets powder coated. So please help
[IMG]local://upfiles/20046/08159174F0D64E5F8A5F8D9183953170.jpg[/IMG]
[IMG]local://upfiles/20046/3A1EA8DD30354CB4873F0BE0951F4708.jpg[/IMG]
[IMG]local://upfiles/20046/7B12FC4408944255AA113726A5C633EE.jpg[/IMG]
Old Jan 20, 2008 | 03:46 PM
Default RE: Need Rim Help
ORIGINAL: CBenRieder600
So I am getting my rims powder coated and i got everything taken off the rims (bearings, tires, weights etc...) but when I got home I realized that this was still on the rim, the first two picts are off the thing that is still on the rim, and the last pict is of the other side of the rim and how I think it should be. Powder coating goes up to 400 degrees so I need to make sure that this isnt gunna get runned by A) the heat and B)by it getting powder coated. Please help
That part is press fit on the wheel and should not be removed. Just have the powder coater mask it of so it's not coated. It will be fine during the process. Make sure you post up photo's after they're done. I'd like to see how they turn out.
I originally posted this responseto the Post your Pic thread.
Old Jan 20, 2008 | 05:10 PM
Cool thanks buddy, should I have them mask off screw holes to?
Old Jan 20, 2008 | 08:45 PM
You shouldn't have to ask them to do that, they should do it automatically. However, best you mention it and have the tell you they do it as opposed to not mentioning it and they don't. It's always nice to cover all bases up front, then there's no question as to what was supposed to happen. Are you going to leave the polished edge on the rim or make it all black like factory again ?
Old Jan 20, 2008 | 09:24 PM
Foght's Avatar
they will put silicone plugs in the bolt holes. and high temp tape on the surfaces that do not get coated.
