Need Help on Sprocket
Old Oct 8, 2006 | 03:21 PM
dk's Avatar
dk
Default Need Help on Sprocket
I have a 96 F3 and when I went to change the forward sprocket and chain I found I could not loosen the bolt that holds the forward sprocket.
Any ideas on how to loosen the bolt, I tried a electric impact wrench and it didn't work ?
Old Oct 8, 2006 | 03:26 PM
4nicho's Avatar
Default RE: Need Help on Sprocket
All I had to do was use a socket with a cheater bar. Just make sure you push the rear brake or you'll just spin it!
Old Oct 8, 2006 | 07:27 PM
Ryder M's Avatar
and make sure u still have the chain on the bike or else holding the rear brake wont help lol
Old Oct 9, 2006 | 01:43 AM
zerochickenstrips's Avatar
Use one of those handheld blow torches (MAPP gas) and heat the bolt, but for no longer than about a minute or two or else you might melt your output shaft oil seal. When it gets nice and hot, hit it wiht that impact wrench until it breaks free. There could be some locktite on the bolt and the heat should melt it. Otherwise, the bolt is just being stubborn and the heat will aid in its removal. By the way, how much torque does your electric impact deliver? A good air impact might be a better solution.
Myfirstcbr
Mar 22, 2013 09:40 AM
DunnRR
Jun 10, 2010 02:31 PM
