Need help: Fork <-> Rotor clearance
Old Jul 29, 2009 | 05:56 PM
Kuroshio's Avatar
Exclamation Need help: Fork <-> Rotor clearance
Was putting the bike back together and now the front right fork is rubbing on the brake rotor. The front right wheel won't turn like it is.
And I do have the spacers on the correct sides (after getting them wrong once). Someone mentioned something about aligning the forks when I searched the forum. But they never went into any detail
Old Jul 29, 2009 | 05:59 PM
Kuroshio's Avatar
Also, everything has indicated the front axle should simply slide in and out. Mine doesn't but it is straight and level. Rolls easily and cleanly on a flat surface.
Old Jul 30, 2009 | 07:26 AM
kjohnson's Avatar
If you didn't have this problem before,your spacers aren't right.You might have them in backwards.As always,get a Haynes manual for your ride.
Make sure your forks are level.
You probably overlooked something.
Old Jul 30, 2009 | 10:01 AM
johnnyx's Avatar
+1. You've got a parallel (up,down) leveling issue, not perpendicular (front,back).
Old Jul 30, 2009 | 08:09 PM
Kuroshio's Avatar
Default Thanks guys
Thanks for the help and replies guys. However its not a backwards tire, bent forks, forks out of alignment or anything like that near as I can tell. The spacers are identical
I went back out and took it all off again. When I rechecked the spacers, they are the exact same size.
I have no clue how the hell the wheel spun before I took off the tire. Or how the hell the PO rode anywhere on it. Super lucky move on my part: while I'm sitting there scratching my head going "WTFH???" USPS pulls up to the driveway and hands me an axle WITH spacers I bought off Ebay last week
Who Dat Popcorn
Oct 3, 2012 11:04 AM
terand
Aug 14, 2012 08:42 AM
hioc1098
Aug 4, 2012 10:13 PM
vincent52100
Jun 9, 2008 09:15 PM
jbodie
Dec 31, 2005 10:41 AM
