Need HELP with electrical problem!
Old Jun 25, 2010 | 02:22 PM
Rmeman86's Avatar
Default Need HELP with electrical problem!
Recently I decided to switch out my fairings, since my old ones were majorly damaged in a fall. I figured since I was taking everything off and had to repaint my gas tank, it would be best to also take the battery out. When I went to place my battery back in, I got the cables mixed up and *spark*. Anyway, now I have no power what-so-ever. My battery is still putting out 12 volts (checked with voltmeter), and my cables seem to have the full 12 volts (also checked with voltmeter). I have no dash lights, no horn, no starter click...no nothing! If anyone has any suggestions I am all ears!!!!!!
Old Jun 25, 2010 | 02:40 PM
spicymeowmix's Avatar
Official Welcome Crew Spicy Cat
fuses.
Old Jun 25, 2010 | 03:33 PM
Rmeman86's Avatar
Where are those stupid things located on the 95 F3?
Old Jun 25, 2010 | 06:23 PM
willduce's Avatar
should be underneath your right handlebar clip on, little black plastic cover on top of side
its probably the 30a main fuse
Old Jun 25, 2010 | 11:16 PM
the 30a is on the starter under the tank by the seat
Old Jun 25, 2010 | 11:44 PM
I think you meant to say it's on the Starter Relay next to the battery. For a total system power loss, that's where to start looking. An easy check would be to see if you have 12v on the Red/White wire going to the R/R under the right side cover below the seat There is 12v there all the time regardless of whether your ignition is turned on or not. No 12v, then bad 30A fuse.
Old Jun 26, 2010 | 10:05 AM
Rmeman86's Avatar
Talking Eat this stupid fuses!!!!
SO I got all prepared today to be out in the South Carolina heat all day, attempting to locate my electrical problem. I took the gas tank back off the bike, and saw a nice little red tab stating "fuse". I pulled it off, and heaven forbid, I found a blown 30 Amp fuse. Went to Wally World, and bought 5 for 2 bucks. Imagine my surprise when my dash board lit back up, and my bike turned over and started! Thanks to all for your help!!!!!! MUCH APPRECIATED!!!!!
01daell
Sep 2, 2021 07:46 AM
kwood
Jun 1, 2020 09:53 AM
vfrman
Nov 16, 2008 10:06 AM
hridlehuber
Apr 5, 2006 04:11 AM
dunn929
Dec 6, 2005 12:50 PM
