my lights keep blinkin
Old Jun 2, 2007 | 03:06 AM
exopforce's Avatar
Default my lights keep blinkin
Today my bike started blinking its lights on n of ...... not really blinking but dimmin low while I'm ridin at a complete stop it doesn't do it..... I don't know what it is n also I still have the heating problem an I wanted to know does coolant rise wen its hot cuz I drained some out n da level went bak up wen it got hot n den I lowered it more so now its on da lower level line but it still da needle goes hot.... and the fan really doesn't turn on dat much I really only hear it turn on wen I'm about to turn the bike offf......
Old Jun 2, 2007 | 05:49 PM
Triax's Avatar
Default RE: my lights keep blinkin
maybe your thermostat isn't working properly or you have and air bubble in your coolant system. As far as your lights go might be a stator getting ready to crap out.
Old Jun 3, 2007 | 03:34 PM
WoodyRR's Avatar
First, you need to learn howNOT to type how you talk..."dat" way people could possibly read your message more clearly.
As far as coolant rising...there is pressure that builds up in the coolant system at higher temperatures, but would return back down to the level you originally had it at. Make sure your measuring fluid levels on level surfaces. I wouldn't touch the coolant (filling or draining) until the bike is completely cool. Not sure if your bike has it or not, but some coolant tanks say "FULL HOT" or "FULL COLD."With all that being said, though, it's not too much coolant that would contribute to your motor running hot. Too little could...I would just check the level frequently after/before riding. If you did just have coolant related service performed, Triax could be right with having an air bubble in the system.
Not sure about the headlight issue. Good luck.
xankriz
Apr 2, 2012 03:02 PM
fordfenatic09
May 17, 2011 10:40 AM
deerslider
Aug 24, 2009 08:23 PM
Ocelaris
Dec 7, 2006 02:14 PM
907hondaf3
Apr 12, 2006 07:13 PM
