My journey of the first Honda
Is there a tutorial on how to use a trailer wiring adapter for integration?
Thanks
This is what ive got, your welcome to it, i did a 98 tail conversion on my bike so i should have everything but the plastic, here is the bracket to mount the light, the light, and the bulbs and bult harness. i looked into the trailer wiring converter while doing my conversion, it wound up being easier for my to just get a light with an integrated turn signal cause i had to replace the light anyways but i dont think those are as easy to come by for a 96. Basically its a adapter that you wire in under the seat and between the harness and light.
https://cbrforum.com/forum/600-modif...-96-f3-107983/
I can probably flat rate these parts to you if you want, you can have the parts if you cover shipping
Just curious, does the brake light bracket just attach to the frame? When I bought mine it didn't have a fender or brake light.
I'll Upload a picture of how I rigged mine up later.
Sorry it took so long to get back. Just figured out that I actually need the plastic under tail for a 96. I actually had to mod the one off the F2 to make it work. If you still have the light later I will pay for shipping. Can't do it right now due to financial stuff.
Funny thing happened today. I was driving down the road today and got the whole running out of gas symptoms. Then the bike shut off on me. Couldn't crank it for nothing! Tried cranking it a of couple times in fear of my battery dying. Reached down and noticed my fuel pump had unplugged. .. Plugged it back in and the bike cranked right up.
They say your bike can run without the fuel pump. Well, mine won't even crank without it.
That was the second time the fuel pump gave me problems. The first time I was driving down the road and I got the run outta gas symptoms. Finally I ended up hitting the fuel pump a couple times and the pump started working. I broke down and got a Honda fuel pump instead of the junk the previous owner put on there. Of course I could've rebuilded it. But, I'd rather have the real deal.
You can run without, you just bypass it completely, it blocks the flow if you leave it in unplugged but you can gravity feed by pulling the line that leaves the pump toward the carbs and plugging that strait into your tank. Ive only done it for diagnostic purposes and it worked fine but i have read you may have problems above 10k if you run it alot like that
BTW, did you read the post I posted on your thread josiahafelix?
