Lost power while on the freeway!
Old 01-06-2010, 05:26 PM
bambam's Avatar
sorry to jump in this but wont an F3 run with out a fuel pump? ive seen this done on a few non-FI bikes for temp. with minimal loss of power except in the high revs. again pardon for the jack...
  #52
Old 01-06-2010, 05:42 PM
Kuroshio's Avatar
F3 can run on a gravity feed. That's why in another thread I suggested a guy quit worrying bout his fuel pump and figure out why his battery was draining while riding (probable stator or r/r problem). Seemed a bigger issue
At this point I don't know if Murdocity has gotten to the point where he can say the pump does or doesn't work. It's been suggested to jump the fuel cut off relay, along with some diags with a multimeter. But not sure if it's been done yet.
Chuckbear also suggested a possible wire short somewhere.
  #53
Old 01-07-2010, 08:01 AM
chuckbear's Avatar
Yea it definitely seems to be something electric. Probably won't really know anything until he grabs a multimeter and a test lead and goes to town.
My money's on the R/R.
  #54
Old 01-07-2010, 04:11 PM
murdocity's Avatar
chuckbear, I've already replaced the r/r a couple of months ago. You think it might be bad again
  #55
Old 01-07-2010, 04:29 PM
chuckbear's Avatar
Oh damn, sorry I missed that bud. Not likely.
Haha it's been a long week.. don't mind me if I'm talking nonsense...
  #56
Old 01-07-2010, 04:40 PM
murdocity's Avatar
hahaha no problem... you got any ideas on a prob or should I just get the meter and check. I ordered the switch contacts and will replace them this weekend, hopefully that solves my problem. I miss riding
  #57
Old 01-07-2010, 05:20 PM
Kuroshio's Avatar
Then just bypass the fuel pump. No fuel pump, no worries if that's the problem. And you'll be riding till you get a chance to work on it.
And if its not the fuel pump, you'll know you need to look elsewhere
  #58
Old 01-07-2010, 10:40 PM
murdocity's Avatar
Kuro or anybody... when i go to jump the fuel cutoff relay, do i 1) cut the black and black/blue wires and connect the jumper cable and 2) Do I reconnect the connection once I connected the jumper cable or do I leave it disconnected. By the way I came home and disconnected the relay and started my bike, it sounded way better and warmed up better. Then I tried to start it with the relay connected and it wasn't the same. Can I ride with the relay disconnected?
  #59
Old 01-07-2010, 10:46 PM
Kuroshio's Avatar
You don't cut anything. If you look at the connector, you'll see where the wire enters the connector. Just jam a wire down in there and it'll make the connection.
Can't comment on the bike running better with the relay simply disconnected.
  #60
Old 01-07-2010, 10:57 PM
murdocity's Avatar
cool, so just jam it in there and leave it connected right? I can ride around like this till I figure out whats wrong? thanks for the help kuro
Quick Reply: Lost power while on the freeway!
