Little hose behing the carb on the head, capped ?
Old Jul 15, 2020 | 08:58 PM
Goathier's Avatar
Default Little hose behing the carb on the head, capped ?
I have 3 little "nipple" on the inlet of the carburator, on the head side.
Two are cap off, but the one on the cylinder 4 is open.
I removed the carb to clean them because I have a crank no-start.
Do I need to cap this off ?
Thanks
Old Jul 15, 2020 | 09:06 PM
Those are the ports used when syncing the carbs. They have to be capped or the bike will not run correctly. Cylinder #1 has a screw instead of a cap but it has to be there also.
Old Jul 15, 2020 | 09:10 PM
Goathier's Avatar
Thanks a lot !!
I will check for the cylinder one for sure,
It started to get worste and worste since I put too much oil in the K&N filter, and now it won't start. I think it's a good thing to clean it, but can this be the reason it started to get worste and worste
Old Jul 15, 2020 | 09:12 PM
You're welcome. Without those capped off you have a giant vacuum leak and the bike will run erratically and very lean.
Old Jul 15, 2020 | 09:14 PM
Goathier's Avatar
Thanks again! Can't wait to try it, also, do you know a good post to help me clean my carb ? I found one but it was for F2.
Old Jul 15, 2020 | 09:20 PM
Goathier's Avatar
Ignore last message, I just found the Service Manual
The principals are the same. There are some great YouTube videos also. I'm not sure if he still has a channel or not but there was a guy called mrmaxstorey who has some awesome how to videos
Old Jul 15, 2020 | 09:22 PM
Goathier's Avatar
If I run it like that without knowing for a "long" time, can I damaged this cylinder because it was running lean ?
Old Jul 15, 2020 | 09:23 PM
There's also a member on here called idodirt. He's a f3 brainiac. He has some great carb posts.
antatious
F2 Tech
Aug 18, 2011 11:36 PM
stefan2m
Apr 22, 2011 08:45 AM
compster
F2 Tech
Jul 23, 2010 08:39 PM
dyracuse
Jan 18, 2010 11:09 PM
your_mom
Dec 3, 2008 07:05 PM
