Lights@#$%
Old Mar 29, 2010 | 06:20 PM
Ok, you have an F3 which is a 3 wire turn signal/parking light setup. You're installing 2 wire signals. How are you handling the the change from 3 to 2 wires ? Are you using a relay ?
Old Mar 29, 2010 | 06:52 PM
CTcbr929's Avatar
July 2012 Ride of the Month
I know its not a safe thing to do intiractive, thats just the best advice i could give since im in the same situation (cuz i obv dont know how to fix it you know?)...
honestly though, no signals is better then breaking down at 80mph on the high way from a blown fuse... so sketchy... when it happened to me my gixxer friend was in front so he didnt see me, and i had a big as truck near me before i could pull off....
Old Mar 29, 2010 | 07:12 PM
intiractive's Avatar
i know konamtbdjc. no hard feelings. just dont want someone on the road and an elderly person or someone on the phone bearing down on them and not "understanding" or "seeing" hand signals for a turn. its better to fix the issue before it becomes a REAL problem.
Old Mar 29, 2010 | 07:21 PM
CTcbr929's Avatar
No I feel you I want to fix mine too, thats why Im hoping someone will come on here with a solution... Hand signals are def not acceptable.
Old Mar 29, 2010 | 10:54 PM
For either one of you, how do you have it wired up currently ? What I mean is what color wire from the signals is going to what color wire on the bike. You're probably going to have to go out there and look at it to know for sure.
Old Mar 30, 2010 | 11:12 AM
CTcbr929's Avatar
Sorry for completely jacking your thread law dog, but I just got back inside from fixing my problem. As Dirt suggested, the wires were on the wrong colors... and before I went out side I randomly came across this thread
https://cbrforum.com/forum/showthrea...063#post900063
and if you look at what AgentRR said, he is correct.
I have not tried them out riding yet as its downpouring out right now, but Im confident its going to work Thanks guys/Dirt n check your wiring Lawdog..
Old Apr 1, 2010 | 09:43 AM
lawdog4545's Avatar
ok here it is. Not only were the wires wired wrong from the guy I bought it from he also had the wrong type of bulb for what he tried to wire up. the front blinkers were wired together to have both running lights and blinkers, but the catch was that the bulb was only a single point contact , so you can only have one or the other. then after blowing through a grip of fuses I also found out that my newly bought aftermarket cat eye blinkers bulb was bad in one of them. So to see if i had wired everything up correctly i bought some simple aftermarket (cheep) blinkers and wired them up and waaahlaah everything is working great. the front blinkers that were wired incorrectly was the cause of my fuse blowing. thanks to ll that commented and gave suggestions. you guys are great.
Old Apr 1, 2010 | 07:22 PM
spicymeowmix's Avatar
Official Welcome Crew Spicy Cat
glad to hear you're up and running!
Old Apr 2, 2010 | 10:09 AM
CTcbr929's Avatar
word
Old Apr 2, 2010 | 03:58 PM
Kuroshio's Avatar
What happens if you disco the running light wire? Just hook up signal & ground?
Lol, late to the party
xankriz
Apr 2, 2012 03:02 PM
fordfenatic09
May 17, 2011 10:40 AM
deerslider
Aug 24, 2009 08:23 PM
Ocelaris
Dec 7, 2006 02:14 PM
Moe Blike
Sep 12, 2006 12:40 PM
