Leaking fuel lines
Old Mar 14, 2011 | 02:42 PM
Hootie233's Avatar
Default Leaking fuel lines
So do the fuel lines that go straight from the tank, through a T and then into the carbs have a LIFE? I will ride for a week then one of them will start leaking, ive changed out the honda clips to normal screw pipe clamps.
I just hate walking out in the morning and see a puddle of gas. Are there any tricks i should know about stupid rubber fuel lines to keep them from leaking?
Old Mar 14, 2011 | 06:23 PM
pacemaker's Avatar
Rubber does have a life. To many variables to mention that can cause it to age & deteriorate. Ethanol blend fuels will certainly cause rubber to degrade quickly.
Old Mar 15, 2011 | 05:40 AM
edwardzx7's Avatar
your o-rings in your "t fitting" is probally shot!!!replace them and it should fix the problem.While your replacing,check and replace other fuel lines also.Some guys on here have pics of what they look like,just do a search on the t fitting.Hope this helps.
Old Mar 15, 2011 | 11:47 AM
Hootie233's Avatar
I went and changed out the two fuel lines going into the carbs. I know the gas was leaking from the point where it connects to the carbs, hopefully the inlet into the carbs that sorta swivels back and forth isnt shot.
platnumbob
Jul 5, 2014 09:57 PM
Mulkxican88
Nov 14, 2013 05:23 PM
lishfireman
Aug 16, 2012 10:02 AM
MegatronousPrime
Apr 29, 2012 09:51 PM
Nauree
Mar 12, 2008 09:22 PM
