leak from pulser cover
Old Mar 28, 2011 | 03:25 PM
csp's Avatar
csp
Default leak from pulser cover
so i have a leak from the pulser cover. it looks like i just have to replace an o-ring. i assume that since there's a leak, there is oil behind the cover. if i pull the little circular cover off will oil spill out? not sure how high the level is behind there... it looks like that little circular cover is sort of an access hole, though? so i'm wondering if anything will come out.
Old Mar 28, 2011 | 04:08 PM
PlayfulGod's Avatar
pulser cover? Do ya mean clutch cover? or ignition/stator cover? The clutch cover will have oil behind it n it will need to be drained b4 removing. Other side should be dry unless the crankshaft seal is shot.
Old Mar 28, 2011 | 04:16 PM
If you're talking about item #3 here, then no, there is no oil behind the cover, and yes all you'd have to do is replace the "O" ring. As PlayfulGod said though, if the CS seal is shot, you could have more oil than just a misting.
Ronayers.com Microfiche Honda>Motorcycle>1997>CBR600F3>RIGHT CRANKCASE COVER
Old Mar 28, 2011 | 04:22 PM
csp's Avatar
csp
yeah #3. sorry if my terminology was wrong. still getting used to all the bike specific things.
kmanracing24
May 23, 2010 12:14 PM
egf4998
Sep 19, 2009 03:21 PM
Uncle
Jun 9, 2008 10:01 PM
DukeCBR
Apr 10, 2008 03:27 AM
