Installed APE CCT...
Old 06-28-2010 | 04:04 PM
mtemple07's Avatar
Default Installed APE CCT...
So I got my new CCT today and I just got done installing it. I have it bolted on but not all the way screwed in yet... I started the bike and there was no sign of ticking at all (which I am very happy of lol) but with the tensior almost all the way extended out I don't know how much I should tighten it... As far as I know to much tighten could cause damage as so can it being to loose.
I let it almost all the way out and still didn't hear any ticking so I tightened the CCT some but now I don't know if it's in a safe spot.. I'm not sure if I have it to tight or to loose!! lol how can you tell??
Old 06-28-2010 | 04:17 PM
cbrf3monkey's Avatar
What I did when i installed mine was...
Started bike, backed it out till it started to rattle then slowly turned it back in till it stop. Then I turned it another 1/4 and locked it.
Old 06-28-2010 | 05:01 PM
mtemple07's Avatar
Thanks for the input monkey!! Went back outside and unscrewed it all the way till it started to rattle and then did what ya said and sounds beaaautiful when I start it up!!! NO MORE RATTLE!!! lol
Old 06-28-2010 | 05:14 PM
cbr900racer77's Avatar
Just my .02 but I would remove valvecover and adjust chain slack per APE's instructions. They recommend 3/8" slack between the cams. To me the extra work is worth the peace of mind.
Old 06-28-2010 | 07:15 PM
Procrastinator's Avatar
I just talked to the guy (Ordered mine...) that runs the CBRZONE APE site, and he said to TDC the engine, then (with the lock screw loose) turn the tension screw with your fingers until you feel it pushing on the chain, then back it off a quarter turn and lock the nut. He said then you want to rotate the motor a few times and recheck the adjustment, to insure its correct.
Old 06-28-2010 | 07:17 PM
They must've changed their specs since last time I bought one. Was it John? He's pretty much the only guy at APE I ever dealt with.
Old 06-28-2010 | 08:11 PM
I forgot his name (Me bad...)
He said it comes with instructions, but he told me the following would work.
I am sure the included documented process must be more intense than the phone verbal, as the butt covering thing is important when it comes to documented procedures.
I myself, plan on following the written docs (If it is included).
Old 06-28-2010 | 09:41 PM
I'm the same way. Like I said, it's been a while (few years) since I've bought one. They last forever so I just swap them over to next project. All that I had bought had written specs and they said 3/8" but my info could be outdated.
Old 06-28-2010 | 09:58 PM
I didn't follow the instructions :P don't remember what they were when I did mine.
I didn't TDC the engine but honestly haven't had any problems.
Old 06-29-2010 | 11:57 PM
Default Super fast!
I ordered my APE CCT on 6/28 at 4pm and it came in today 6/29 at about 7pm! HOLY CRAP! That's only 27 hours!!!!!
http://aperaceparts.com
mjp94cbr100f
01-15-2013 01:41 PM
Z Freak
01-18-2012 09:59 PM
dangerranger21
05-09-2008 11:20 PM
snowboarding82
06-09-2007 04:00 PM
Ruftags
05-26-2007 01:29 AM
