Instaling alarm. pease help if you can
UPDATE:
Got everything connected and the remote start as well. All good and working super...
The last thing to do is make immobiliser out of the relay. So the PINK wire becomes ground when the alarm is been trigered and goes OFF, wich means that relay is active.
So i can connect PINK to conntact 85 and + to conntact 86. Now i have conntact 30 & 87 left to be cut into some wire for this to work.
The question: what wire should i cut the relay intofor it to become ammobiliser.
Ok. i got it all figured out. Instead of connecting 30 and 87 i'll connect 30 & 87a to the kill switch.
in normal state 30 & 87a are allowing the curent t flow through. So when the allarm goes off 30 & 87a will break off and the kill switch will be on so the starter wont crank.
Special Thanksto dementedf3.
Project finished with %110 sucsses.
Cheers
Cheers
