Help pease
Old Aug 16, 2009 | 12:07 AM
dopey's Avatar
Default Help pease
Hi im new to this forum and this is my first post but im in need of help
i just got my first bike its a 1988 honda hurricane 600 and i need a CDI box the one i have is no good
if anyone can help me find one id grately appreciate it i have a second box but it looks like it uses a single large pin connector but mine uses a 6 pin and a 4pin connector if anyone has one they are wanting to get rid of please let me no
thanks for your help
DOPEY
Old Aug 16, 2009 | 10:14 AM
dopey's Avatar
thank you
Old Aug 16, 2009 | 01:39 PM
Billistic's Avatar
How do you know that the CDI is bad?
Old Aug 16, 2009 | 04:59 PM
dopey's Avatar
I am not getting spark to any of the cylinders so i looked in the book and it gives step by step directions on how to diagnose the problem so i went thru the steps and i have power going into the CDI and the book says to next check the resistance with an ohm meater of of 2 connectors i did that and the book says it should be running at about 450 to 500 ohms but mine is showing 4.5 meg ohms also when i bypassed the CDI by connecting a wire to the coils that goes back the the CDI box and tapped it onto a ground and when i did that i was getting spark so i have come to the conclusion that the CDI unit is bad
Old Aug 16, 2009 | 05:00 PM
Halfpint's Avatar
check your Run/Switch for short and the fuse
Old Aug 16, 2009 | 05:39 PM
dopey's Avatar
the run switch doesnt look like its shorting i would think a short would pop a fuse and i dont have any probem with fuses they are all good
Old Aug 16, 2009 | 05:47 PM
dopey's Avatar
i guess i shouldnt be using the term CDI but instead SPARK UNIT
Old Aug 16, 2009 | 09:23 PM
geckert's Avatar
ebay?
Old Aug 16, 2009 | 09:50 PM
dopey's Avatar
i looked but only found them for the 1000cc model would anyone no if they are the same im going to assume that they are different but i dont no any help would be greatly appreciated
