ideas for a front stand????
Old Aug 7, 2006 | 07:31 PM
Honda_CBR600's Avatar
Default ideas for a front stand????
I am going to be replacing the seals on my forks shortly. I do not own, or know of anyone who has an actual front stand. Are there any ideas that work well to keep the front end off the ground??????
Old Aug 8, 2006 | 05:21 AM
gerharddvs's Avatar
Default RE: ideas for a front stand????
I have a very easy solution. All you need is two tiedowns (preferably the ratchet types) and an open rafter in your garage. You tie the one end of the tiedown to the rafter and then hook the other end to your handlebars. This means you are going to have two tiedowns tied to the rafter and then the other ends to the left and right handle bars.
Try and space them far apart on the rafter. I found that on the F3 there’s not much space on the handle bars so I just hooked them to the left and right sides of the yoke. Then you just ratchet the tiedowns up untill your front wheel is in the air.It works pretty much like a chain block. The bike will wiggle around but don’t worry the bike can’t go anywhere. If it will make you feel better you can put the bike in gear. Just make sure the tiedowns are secure to the bike and that they don’t touch the fairing or screen as to scratch them. Don’t worry about the rafter. Your roof is much heavier then the bike. Unless its rotten it won’t brake. Just don’t try to sit on the bike
Old Aug 10, 2006 | 12:52 AM
transamlt1man's Avatar
Yep lift it from the ceiling. Thats what I do.
Old Aug 10, 2006 | 04:15 PM
fullmetalf4i's Avatar
when we did it with the F2 we used the tradtional fort lift (the standard pitbull one) and then when it was up in the air we put some bricks on a bucket and put those under the frame sliders....
BENNYCBR
Jan 29, 2008 10:51 PM
bluej511
Jan 11, 2008 11:03 PM
sushix2
Mar 15, 2006 01:32 AM
