how do i get the ignition out?
Yeah....you're not gonna get it out....even with the right tool. Damn star bits strip as soon as they see anything coming towards them. Plus, that sucker is loc-tited like you would not believe. I drilled the heads off the screws. Took the ignition out so some screw was exposed. Then I used vice grips to turn them out. It was HARD.
if you see the other post. he's got two keys one for the gas cap and the other for the ignition. Try takeing off the helmet lock. I'm pretty sure that should match the ignition. no one really changes the helmet lock.
Do you still have the key to the gas cap? try to open the helmet lock, if it works than the ignition was changes...if it doesn't than the gas cap was changed.
Taking the rear peg off is easier than the ignition.
my .02
my .02
