hot rectifier problem
Old Jul 24, 2009 | 07:43 PM
acdc88's Avatar
Default hot rectifier problem
i have a 95 f3 and whenever i ride the right side of the seat gets really hot. i noticed that the only hot area of the frame was the rectifier and the grounding mount that the rectifier sits on.i popped the clip that mounts to the rectifier off and the top right 'tooth' (yellow 3 in the claymer repair guide) was burnt and had corrosion all over it and looked as if it had been sparking. i was just wondering if the rectifier is blown or if it is always supposed to be warm.
Old Jul 24, 2009 | 08:44 PM
The regulators get hot. But not as hot as you're describing. Heat can also be generated by poor connections. Do a search on Regulator / Rectifier in this forum. There's lots of information on troubleshooting as well as replacing it with one from another manufacturer's R/R which has better heat sinks for cooling.
Old Jul 25, 2009 | 01:29 PM
kjohnson's Avatar
Clean up the connection.Parts Unlimited makes a kit for this particukar problem,cost is $10 retail .I have 3 F2/F3 CBRs and I've seen this on all but one.It's normal on CBRs.
idodirt is the man on this topic.Listen to him on this,we all do.
Holla back.
Old Jul 26, 2009 | 01:07 AM
acdc88's Avatar
i clipped the connection that looked corroded and burnt and the rectifier didnt heat up nearly as bad. tomorrow im gonna pop out the old connector, re soldier the wire and all should be good. thanks for the help!
Old Jul 26, 2009 | 02:41 AM
johnnyx's Avatar
The F2 forum has an AWESOME sticky on rectifier troubleshooting. it applies to all bikes.
sanlot17
F2 Tech
Jul 31, 2014 03:16 AM
sportracer07
Jan 11, 2014 12:45 PM
36emt37
May 1, 2007 11:53 AM
Kevo
Mar 3, 2007 03:07 AM
bren1422
Sep 9, 2006 07:30 PM
