Help Neutral is funny after lowside
Today its acting up. Rode to work fine. My cousin wanted to ride today and so he wanted to pick up my bike from work. He got down the block and it was bogging and I had to pick him up from the parking lot 2 blocks down from my work place.
Symptoms:
-will run and stay running in gear-
-starts up runs and revs fine but when shift to 2nd gear it bogs and wants to die out-
-will shut off if in neutral and you kick the kickstand down-
-With kickstand down if you push till you see neutral light it starts back up-
-In neutral it will idle and then the neutral light with flicker and it will die out-push to see neutral light it starts back up again
-What I have done before I crashed was cleaned out the carbs and last night I poured some seafoam in the tank to clear out anything else. I'm out of ideas on what to do now. Any suggestions other then a neutral switch? (I did search and that's all I could find)
Symptoms:
Symptoms:
Symptoms:
2. Also check to make sure the shift lever and linkage is not broken or bent from the low side.
It sounds like so electrical problems IMHO. Check that all the connectors are fully seated and you didn't damage any wires in the lowside.
