Help cbr won’t start!
Old Sep 10, 2021 | 01:00 AM
dre01's Avatar
Default Help cbr won’t start!
Bought a bike that had been sitting since 07’ told I just had to clean the carbs change fluids etc. turned into a whole first bike project. I’ve changed the sparks, coils, fuel pump, r/r, generator, cleaned and replaced jets replaced one float that somehow broke during the build. I’ve had the bike start on multiple occasions, I’ve ridden it once sat overnight and haven’t been able to keep it running to ride at all. This is my first bike so I’m not experienced by any means and no shops will work on a 95 out here. Anything helps, thanks!
Old Sep 10, 2021 | 04:13 AM
Welcome to the forum dre01,
Can you provide more details for the members here to give you some help.
Exactly what is happening, when you switch on, try to start etc.
As it has started before we can assume compression is ok, you then have three elements spark, fuel and air. It sounds like it might be air / fuel related.
Have you checked all the hoses for air leaks, have you checked the fuel pressure regulator.
It might also suggest that the carbs may not be properly cleaned, then can be exceptionally difficult to get right and would top it running.
Old Sep 10, 2021 | 09:45 AM
dre01's Avatar
It will turn over strong and catch for a second but will not fully start. now it won’t even start with starting fluid. Should i order a different jet kit?
Old Sep 12, 2021 | 11:01 AM
Why did you change the jets, I would go back to stock but make sure they are absolutely clean along with all the 'holes'
Courtesy of 'IDoDirt'
92outkasf
Jan 28, 2020 02:12 PM
muppet1022
May 23, 2014 03:25 PM
cbrf3600
Jan 7, 2012 07:44 AM
theman88b
Aug 28, 2007 02:33 PM
yohuallin
Mar 12, 2006 07:50 PM
