handlebar question
Old Oct 25, 2006 | 11:28 AM
Tatternuts's Avatar
Default handlebar question
Here is the problem. The bike has been lowered by 1" from the person i bought it from. I like the way it handles now, however the handlebar/clipons are a little low on the forks. I want to raise them up to the top of the forks were they used to be, however once i raise them the dimple on the clipons will no longer be engaged in the fork tube clamps. (hope i explained that well enough) I am a little concerned that the dimples on the clipons are there for safety if they loosen, but i really dont see them coming loose if i raise them and properly and torque them down.
what are your guy's thoughts
thanks
Old Oct 25, 2006 | 11:47 AM
Stunter Bob's Avatar
Default RE: handlebar question
umm...your bikes been lowered about 2 inches
easy fix to raise it back up
put the bike on a rear stand...put a jack under the header
loosen the 4 bolts on the upper and lower triple that hold the forks in place....then simply jack it up till its all the way back to stock
then tighten it all back down and your set
Old Oct 25, 2006 | 02:07 PM
Tatternuts's Avatar
I would raise it, but the problem is the rear has also been lowered. He changed out the dog bone in the rear and i do not have the factory one. So basically raising it back up at the moment is not an option. I do like how it handles the way it sits, i'm just concerened about raising the handlebars and not utlilzing the dimples on the clip-ons that engage in triple tree clamps.
Old Oct 25, 2006 | 02:32 PM
you should get a stock rear link then....
you can bring the clip ons back up and be ok..as long as you tighten the crap out of them
i cut those little dimples off mine so i could turn my bars out
see below
http://i56.photobucket.com/albums/g1.../pics023-1.jpg
its not a good idea..just the other day i was riding and when i pulled it up my left clipon folded in on me..scared me pretty good
and plus...doing that will look retarded lol
good luck though
Old Oct 25, 2006 | 03:08 PM
Tatternuts's Avatar
Yikes well the clip-on coming loose sounds kinda scary. did it come loose because you did not torque it down tight?? I hope mine don't do that!!
Old Oct 25, 2006 | 03:37 PM
i thought it was pretty tight..but i guess not cause it folded in lol
i took it off and scarred the **** out of the fork with a screw driver so the clipon kinda had some rough spots to grip to...then i tightened the crap out of it..should be good now
Old Oct 27, 2006 | 03:34 AM
kwong2001's Avatar
The dimples are there for safety reasons, if you notice, there's a little ring at the top of the forks that makes it impossible to remove the clip-ons without first removing the little ring. This way (with stock suspension height), if the bolt securing the clip-ons suddenly loosens, the clip-on won't come up past the dimple and therefore the clip-on won't move around.
Now if you do raise the clip-ons up higher, you'll probably have problems with the master cylinder hitting your fairing, and your throttle and clutch cables might not allow for full movement of steering.
Old Oct 27, 2006 | 02:22 PM
Tatternuts's Avatar
Hrmm i may have to make some extensions from the clips-ons to seat back into the triple tree clamp then. I do see how the it would make impossible to slip out now when the bike was set at the proper height.
Uniqsol
Jun 1, 2009 12:44 AM
mowdiddy
Oct 13, 2008 07:44 PM
CBRrider01
Aug 22, 2008 12:42 AM
billywobbles
Apr 14, 2007 07:07 PM
adam833
Dec 5, 2006 10:35 PM
