handle bar weights removal
Old Apr 12, 2008 | 02:54 PM
pointman's Avatar
Default handle bar weights removal
how are the weights in the handle bars removed i need to change mine out along with my throttle tube ? anyone know how to get the weights out mines needs to be replaced .
Old Apr 12, 2008 | 08:21 PM
Scrufdog's Avatar
Default RE: handle bar weights removal
I read on here sometime last year that soaking it with PB blaster works pretty well, as well as dishsoap. Once it gets a good soak on, wiggling in and out will eventually pop them out.
Old Apr 13, 2008 | 12:12 PM
pointman's Avatar
kewl once the new ones get here i should see the make up n hopefully figure it out
Old Apr 13, 2008 | 12:42 PM
marc0011's Avatar
If you're talking about the weight inside the bar. I took the handle bar off and then screwed in some bolt that I didn't care if I messed the head up on. Put a little dish soap in there and then pulled on it. It takes a little work but it'll come out.
Old Apr 13, 2008 | 03:16 PM
SilverF3's Avatar
What dos takein the weight out do, and if you do , can you still put barends on it ?
Old Apr 13, 2008 | 04:26 PM
pointman's Avatar
well i am takin them out to change them out i they snapped when i got into my accident , its been a slow rebuild im basically done. need to go get a carbtune n sync but im thinking if i should put in a jet kit gotta see how much they gonna charge at the shop . But i think the weights help with the vibrations dont quote me on that tho
CBRmax
Feb 22, 2011 11:32 AM
halomatic
Jul 3, 2010 10:53 PM
P_Glasovatz
Mar 18, 2010 09:02 PM
jimmydks
Jan 9, 2009 08:03 AM
asc
Nov 9, 2006 02:22 AM
