Guys Need Help Please
Old Oct 10, 2008 | 06:16 PM
allspoolin4's Avatar
Default Guys Need Help Please
hey guys i have a fuel prob, i took the bike out for its maiden voyage today and was riding for about 45 minutes, cruising at like 50-60 and when i approach a stop shift down and when i come to that complete stop the bike stalls, its whenever i come to a dead stop pretty much i cleaned the carbs recently, took off the bowl took out both jets, floats and another doodad that sits under neath the float with a rubber point almost at the end. I soaked the jets in sea foam and sprayed all the carbs down with carb and choke cleaner also all the bowls, i do have a dead battery so i just wanted to add that too the mix. Any help would be really appreciated guys.
Also the two rear plugs underneath the gas tank, i have them plugged,, guys i need help
Cheers,
Alex
Old Oct 10, 2008 | 07:11 PM
Default RE: Guys Need Help Please
If you have a completely dead battery, then that alone could be your problems with stalling. At low idle, the alternator doesn't generate enough energy to keep the battery charged and the engine running. Generally the RPM's would need to be maintained above about 3K. Put a known good battery in it and see how it does then.
Old Oct 10, 2008 | 07:29 PM
Hurricane rider's Avatar
yup. known good battery first, if your battery wont hold a charge, thats 100% of your problem.
Old Oct 10, 2008 | 11:27 PM
well i just picked up a batt tonight and its on charge, tomrorow i gotta go the the rennesance fair in pa with ms.wonderful so sunday will be test day i think,
thanks guys.
alex
speeddemonx60
Feb 7, 2010 11:02 AM
3v1lj03
The Hurricane Saloon
May 1, 2009 09:59 AM
gotcbr
Apr 29, 2009 04:23 PM
Apocal
Jul 23, 2007 08:11 AM
acidfire52
Jul 17, 2007 07:27 PM
