General F3 Q's
Old Aug 29, 2007 | 06:55 AM
marc0011's Avatar
Default RE: General F3 Q's
Hey there CBenRieder600,
On the fluid that has leaked from the forks, it doesn't mean that front wheel is going to fall off or something like that. What will happen is when you hit the front brakes hard, the bike with "dive". What I mean by that is that the forks will compress more then usual (6" or so in a really bad case) because the spring alone can not absorb enough of the compression energy. The forks use a combonation of spring compression and fluid to absorb this energy. It will also make a huge mess if they leak enough. Like Chad600 said, the forks are a sinch to do. They just take a little while to do.
About the noise when the bike is cold, sounds like a typical CCT on it's way out. Mine sounded like a marble bouncing around inside on the right side of the engine when it was cold. It's a sinch to replace (about 20 minutes). You'll get some guys that swear by the manual tensioners and some that swearby the OEM CCT. I went with OEM because all I had to do was put it in and put everything back together. A manual CCT... you have to set the tension.
Old Aug 29, 2007 | 04:57 PM
CBenRieder600's Avatar
Do I need to replace the lost fluid?
Old Aug 29, 2007 | 11:18 PM
Sand.Man's Avatar
Yup, you'll need to replace the fluid and seals.
I havent had my F2 shocks apart yet, but from doing older bikes I understand that they can be a bitch!
If you're new at the wrench game, I'd have somebody who knows what they're doing check it out, or at the veryleast read up on the internet for some directions.
Old Sep 1, 2007 | 02:32 PM
thanks hershey
Sprock
The Hurricane Saloon
29
Aug 3, 2013 09:30 PM
novice
Jan 23, 2012 04:28 PM
jonny599
Apr 25, 2008 11:31 AM
darkness954
Dec 17, 2007 03:36 PM
HondaKidF1
Sep 16, 2006 09:41 AM
