Fuel Tank
Old Jun 5, 2009 | 12:56 PM
kmanracing24's Avatar
Default Fuel Tank
Do I need to drain the tank to remove it or can I just turn the petcock off and hope for the best? 95 f3
Old Jun 5, 2009 | 01:22 PM
johnnyx's Avatar
No need to drain it, but keep in mind it's going to be HEAVY, depending on how much gas is in there. The hoses are very short, so you're not going to be able to get at whatever it is you're trying to get at without removing them. This means turning the petcock off is irrelevant. Make sure you clamp off the two hoses before disconnecting them, but honestly, syphoning out the gas takes 3 minutes, and makes things generally easier.
Old Jun 5, 2009 | 01:46 PM
well my starter stopped working. i need to get at it. First it would only click. Then after a while, it started to squeal. Im more than positive its the starter. I have a manual so that helps. (Yeserday it tipped over because of hot asphalt. Picked it up and it wouldnt start. Luckily I knew how to start it with it in gear or otherwise I would have been stuck in the middle of nowhere yesterday). If anyone can help with starter testing or removal that would be great. BTW its a full tank but I can lift it, I just want to disconnect the fuel line so it can completely remove the tank with out it spilling every where. The starter would click, engine wouldnt turn over, now it squeals with no engine turning. Thanks though
Old Jun 5, 2009 | 04:10 PM
johnnyx's Avatar
Then, yeah, clamp off the two hoses, then just disconnect them by hand and lift it out. Not a big deal.
Make sure you perform any routine maintenence while you got all that disassembled. Fuel filter, air filter, etc etc etc. That stuff is cheap enough to replace before you NEED to, just to avoid having to disassemble all that crap again when its mandatory.
Old Jun 5, 2009 | 04:13 PM
johnnyx's Avatar
On a related note, I had a BMW (car) that was doing what you're saying. It turns out the water pump locked up, which also controlled the oil flow, so the engine had no oil going through it. The sqealing sound was the dry cylinders rubbing against the engine block. I ended up scrapping the car.
I'm not saying that's your problem, just sharing a horror story.
dscott3984
Apr 28, 2014 01:11 PM
jveach
Jun 12, 2011 12:45 PM
mojo
Apr 30, 2007 01:01 AM
