Fuel pump question?
Old Jul 11, 2008 | 03:47 PM
njdjh2o's Avatar
Default Fuel pump question?
At lunch time I went out to see if the fuel pump was clicking/pumping. Felt the fuel pump with the engine running and it have irratical pumps (p). P....P...............P....P ..P.P.P.P............P..........P...........P. Every time it pumps the engine idle goes up.
Revved up the engine and is still pumped irratically. I have going to replace the pump, because shouldn't it be a constance pumping action instead of an irractic one?
Thanks
SGB in PA
Old Jul 11, 2008 | 06:17 PM
jalen11598's Avatar
Default RE: Fuel pump question?
It's been about a year since I messed with the fuel pump, but if I remember correctly, I do believe thats the way it's suppose to perform. I don't think it's a constant pump.
Old Jul 14, 2008 | 10:42 AM
follick's Avatar
had the same problem, the pump cant pump good if the filter is blocked, i changed the filter and never had a problem again.
Old Jul 14, 2008 | 04:53 PM
njdjh2o's Avatar
I didn't think about the fuel filter, will look at that tonight. I have a fairly clean one from my parts bike for the time being. Will order a new one if this solves my blogging problem.
Old Jul 17, 2008 | 10:42 AM
nrecore0223's Avatar
If the bike is running than the fuel pump is working. They pump should pulse erratically. Its not constant. I would look at your filter and all of your feul lines. See if there is anything in the lines. Also make sure you have the 2 tubes under the tank connected.
Old Jul 17, 2008 | 12:04 PM
kjohnson's Avatar
The pump is self priming,that's why it does that irratic stuff.
gorj
Jun 13, 2013 05:38 PM
donnygeewebb
Feb 18, 2012 01:59 PM
sean1037xx
May 24, 2011 07:05 PM
Drewsive
Dec 24, 2009 12:22 PM
Chuck Norris
Jan 5, 2007 04:39 AM
