front wheel bearings always going bad!!!!!!!
Old Nov 24, 2008 | 10:58 AM
cbr600f3covina's Avatar
Default front wheel bearings always going bad!!!!!!!
ok i replaced my front wheel bearings and then maybe 4-6 weeks later im starting to feel the front wheel wobble again and i replaced dust seals, bearings and center spacer when i did it i cant figure it out any suggestions????
Old Nov 24, 2008 | 12:05 PM
chrisc321's Avatar
Default RE: front wheel bearings always going bad!!!!!!!
Did you use the correct torque?
Old Nov 24, 2008 | 12:11 PM
Sand.Man's Avatar
Check your head bearings, front tire for cupping, stuff like that.
Old Nov 24, 2008 | 02:20 PM
Northernfirepower's Avatar
Front end wobble, are you sure that the tripple clamps are inline/forks arent twisted some? Ive gone thru that swapping forks.
If not, have you ever adjusted your fork settings? Are they equal? Also I believe that if one fork has more/less oil than the other you can have some troubles.
Old Nov 24, 2008 | 04:06 PM
i used the right torque, but what is "cupping"? ive adjusted the dampeners on the forks but i dont know if i did it correctly.
Mbennett
Aug 6, 2013 03:17 AM
Procrastinator
Jun 23, 2010 05:49 PM
pr0jktmayhem
May 25, 2009 11:31 AM
Craigart14
Nov 30, 2008 11:20 PM
city worker
Jun 10, 2006 12:44 AM
