front fairing swap to f4i
Old Mar 5, 2010 | 01:01 AM
cbrseabee's Avatar
Default front fairing swap to f4i
Ive seen alot of guys do the swap to the f4i front fairing and I was wondering what all i would need to be able to do it. like any new brackets for headlights that I need to make or can I buy, cuz if I have to make em then im just gonna do some custom head lights. and does it just bolt up or will there be cutting or drilling involved? thanks for any help.
Old Mar 5, 2010 | 12:37 PM
STREETFIGHTER88's Avatar
Headlight screws to the inside of the F4i Fairing.
Need the F4I speedo and fairing mount then need to cut the old bit that bolts to the frame off the f4i and f3 bracket and weld the f3 one onto the f4 bracket.
Side fairings was a matter of making brackets to bolt one end to the f3 fairing mounts then the other end of the bracket you screw the f4 fairings to, it was a tight fit lol
Old Mar 6, 2010 | 11:24 AM
orangef3's Avatar
Exclamation
when i did my front swap i just made a bracket out of 2 inch wide aluminum that went from the f3 fairing stay mounting points to the f4i stay and filled all the holes in the f4i sides and made my own brackets...search for demented f3's thread on it there is a pretty good write up there
Old Mar 6, 2010 | 07:18 PM
cbrseabee's Avatar
Default thanks
thanks guys
ozf4i
Jan 12, 2014 12:58 PM
An01InAZ
May 31, 2012 09:12 AM
cpalmer00
Jun 6, 2010 10:33 AM
DesF4
Sep 15, 2009 07:16 AM
exz5string
Jun 5, 2008 11:23 PM
