fork seals
Old May 4, 2006 | 09:32 PM
CBRider206's Avatar
Default fork seals
if your fork seals are going bad and are leaking, where would it start to leak out first? thanks... i cant tell if its fork seal leaking or some other stuff.. thank you
Old May 5, 2006 | 01:01 AM
transamlt1man's Avatar
Default RE: fork seals
You will see oil on the shinny fork shaft or leaking where they come together. Where the inner shaft goes into the outer shaft.... i hope this helps im trying to make it as easy as possible.
jaysee
May 18, 2012 06:27 AM
stealthCBR929
Feb 27, 2012 06:37 PM
tareemup
Apr 29, 2009 09:50 AM
ldv12
Apr 14, 2009 08:15 PM
