Flush Mounts
Old Apr 11, 2006 | 02:43 AM
jeffreyg's Avatar
Default .
Old Apr 11, 2006 | 10:17 AM
migf4i's Avatar
Default RE: .
jeffreyg that definitely helps out! I appreciate any insight into the electrical systems. I am decent with the mechanical end but when it comes to the electrical side i am clueless... thanks again!
Old Apr 11, 2006 | 02:42 PM
jeffreyg's Avatar
Default RE: .
Anytime bro
Old Apr 12, 2006 | 12:13 AM
kustom98f3's Avatar
Default RE: .
exoticsportbike.com has plenty of turn signals available that are DOT. Just get one of their dual filament setups and you'll be all set.
Old Apr 12, 2006 | 11:58 PM
Royce's Avatar
Default RE: Flush Mounts
Do you have the Watsen lights? I have recently ordered the HB lights for my '03 RR and found out that they are on back order. I thinking that I may cancel the order after seeing the Watsen units. They are sweet looking!!! About twice the cost but at least they can be seen from head on. If indeed you have them, how do you like them? Were they easy to install?
Regards,
Royce
ORIGINAL: WolfPack
Not sure if the HB lights are LED's, but Watson has a running-light module that runs the LED's @ 1/2-power as marker lights and then blinks at full-power when you hit the switch....Heres the Wiring diagram they sent with them...they were $12(US)...
Heres the website(Look at the write up on the bottom of the page):
http://www.watsendesign.com/products...INK/index.html
and here's the install sheet...:
[IMG]local://upfiles/3756/A361E41CDA7B494C909CF1C0B3D04B1E.jpg[/IMG]
Old Apr 23, 2006 | 08:24 AM
jeffreyg's Avatar
By the way...
I installed HB fluch mount LEDs, They look great, however, They cannot really be seen head on. So I bought flexible LED strips and wired them up to my blinkers. I used double stick tape to fasten them to the plastic on each side of the radiator facing north so they can be seen from the front. The picture suggests the LEDs arent too bright, the LEDs are brighter in "real life".
I will probably drill and fasten them better later on, I just hate the thought of taking a drill bit to a 2006 CBR1000 that has 236 miles on it!
here is a pic...any suggestions or comments?
[IMG]local://upfiles/6199/F30F22E98F2C4DFD80B5FC9088708524.jpg[/IMG]
nickp123
Mar 21, 2011 01:03 PM
hopper662
Jul 28, 2008 11:39 PM
Lego
Jun 28, 2008 07:51 PM
lance_buma
Jun 22, 2007 12:23 AM
Da CbR KiD
Mar 20, 2006 08:01 PM
