Flooded Question
RE: Flooded Question
If it's a stuck float and you dont want to rip the carbs out you can tap on the float bowl with something that wont damage it like the handle of a screwdriver, vibration is a powerful tool and can free up stuff like that.
But you may want to take the carbs out and clean them thoroughly and properly to be sure that everything is working perfectly.
Can you be more specific about which vent the fuel is leaking from? I'm not quite sure what you're talking about in that regard. (outer air vent cleaner?)
It is on the air hose coming from under the headlight along the outside of the frameon the left side (sitting on the bike). The box (outer air vent cleaner/filter) is before the hose goes into the air vent soleniod valve behind the air box and carbs. Hope this makes sense.
Tool Man
Tool Man
