FAQ's(Frequently Asked Questions)
Old 05-04-2010 | 08:00 PM
Krux's Avatar
Default FAQ's(Frequently Asked Questions)
Hey guys figure I would make a list so this would help everyone out with questions that come along. If you have anything good or want to add let me know and ill add it to the list. I left blanks since I myself have no clue.
Here are the most common questions asked about the F1:
Are these bikes fuel injected:
No. They have a carb. Yet this year they have a fuel pump compared to the older models
Grade Gas:
87
What are the most common power mod's to do:
1.Rejet
2.-1 Front Sprocket, +2 Rear Sprocket
3.Slip On(aftermarket exhaust)
4.Air Filter
What are the most common body mod's to do:
1.Undertail kit
2.Hid's
3.Good frame sliders(One's that require no cuts haven't had significant luck with working)
4.Tires(Find a good brand name that's proven to work)
5.Aftermarket Windscreens
6.Good Chains
What are some good websites to get parts for it:
Oem:
www.bikebandit.com
Aftermarket:
Fuel pump not working?:
https://cbrforum.com/forum/cbr-600f3-17/fuel-pump-contacts-109187/
How to repair your fuel pump:
https://cbrforum.com/forum/stickies-91/how-repair-your-f3-fuel-pump-102151/
I hear a rattle when start up and at 5,000 rpm's. What is it?:
CCTL Link:
https://cbrforum.com/forum/stickies-91/how-replace-your-automatic-cam-chain-tensioner-104184/
Oem CCTL to a APE:
https://cbrforum.com/forum/stickies-91/replace-your-oem-cct-ape-107855/
Rectifier not working?
If your having a dead battery or out of no were your motorcycle shuts off? Check the output voltage on your battery when the bike is on. Rev it to 5,000 rpms and if you don't see the voltage jump into the 14's chances are your rectifier gave out. This is a common problem on a lot of cbr's.
My valves tick is this normal?:
Yes this is. In order for your valves to work properly you need to have clearance. With having clearance you get a "ticking noise" which is normal. If you don't have any clearance they will be to tight you will have major major problems.
Are the F3 good??: Here is the super review on it with spec's:
https://cbrforum.com/forum/showthread.php?t=96869
Old 05-04-2010 | 08:27 PM
karsonsdaddy's Avatar
Nice... Thanks for starting this... Some of the stuff you have up already I didn't even know myself.
Subscribed for more info when people add it!!
Old 05-04-2010 | 11:15 PM
chuckbear's Avatar
Nice job. I'd add something about the R/R being a common fail point.
Old 05-05-2010 | 12:53 AM
spicymeowmix's Avatar
Official Welcome Crew Spicy Cat
+1
I am personally going to do a How-To recover your seat.
Had me puzzled for a bit.
Old 05-06-2010 | 06:17 PM
Krux's Avatar
ya if you have a link for RR testing ill put it in there
Old 05-06-2010 | 10:02 PM
chain cleaning is a big deal too,
not a F3 issue really, but since the F3 is a common starter bike, its home to many "how to's" as a first learning basis.
Old 05-07-2010 | 08:42 PM
96@cbr's Avatar
You can use shell rotella oil. 5w 40 only
and use the right size tire unless you have a wider wheel. (160/60 17 is factory)
Krux
05-31-2021 02:48 AM
Krux
05-10-2010 09:58 AM
Krux
05-08-2010 03:09 AM
Krux
05-06-2010 08:10 PM
Krux
05-04-2010 08:41 PM
Quick Reply: FAQ's(Frequently Asked Questions)
