F3 start problem
Old Apr 11, 2009 | 06:07 PM
marstenb's Avatar
Exclamation F3 start problem
My F3 has been sitting for the winter. It initially started up after a quick battery charge and idled... but when I turned the throttle at all it would shut off.. After that it would want to start but just couldn't quite fire up. A day later I again had it started and idleing for a few minutes and then it shut off. I did change all the spark plugs as they needed to be changed anyways but it did not help the problem. Any suggestions? (there is old gas in it from about 4 months ago... but I don't think thats the total problem, however I will be draining the old gas and putting new gas in tonight).
Old Apr 12, 2009 | 01:24 AM
f3BikeR's Avatar
That just may be your solution right there...
Old Apr 12, 2009 | 02:12 AM
marstenb's Avatar
Default tried new gas didn't work
I did put new gas in and it did not make a difference.... any other suggestions?
Old Apr 12, 2009 | 03:16 PM
f3BikeR's Avatar
Did you drain the carb bowls and then put new gas? If not, there's still plenty of old gas in the pump, fuel filter, hoses, and carb bowls that needs to be pushed and drained out!
eaglesan13
Jan 29, 2012 11:34 AM
purpleslug
Oct 17, 2009 03:45 PM
TSMMadMax
Jun 26, 2008 05:10 PM
97slowbird
Jan 30, 2008 01:49 AM
Crashbaby
Nov 18, 2005 03:40 PM
