f3 speedo troubles
I just bought a 96 f3 the other day. The person that had the bike before me installed f4i gauges. Everything on the gauges works perfectly except the speedometer and odometer. Any help getting my speedo working would be greatly appreciated. Which wires make the speedo work? Sry if these r dumb questions, i'm kinda new to working on honda's.
Check your wiring to verify it is correct. I don't know which are specific to the
speedometer/odometer but if they are all correct to the following,
it should be correctly wired.
F3 to F4i
Green/Blue---- Green/Blue
Pink/Green----Pink/Green
Black/Brown----Black/Brown
Brown----Brown/White
Light Green/Red----Light Green/Red
Orange----Orange
Light Blue----Light Blue
Blue----Blue
Blue/Red----Blue/Red
Green (one of them)----Green
Green/Black----Green/Black
Yellow/Green----Yellow/Green
Pink (solid pink) - ground this out (other green)
Brown/Black - fuel reserve sensor - not used
Red/Green - battery(+) - connect to battery
White/Blue - fi indicator - not used.
Yellow/Black----Green/White This is where you have an option..
courtesy of iwanta900rr: .....I finally discovered how to use the 'FI' bulb as the kickstand indicator!! To add, it is also functional in that if you put the kickstand down in gear, it stalls! f3's yellow/black wire connects to f4i's white/blue wire AND NOT it's green/black wire.
Hope this helps, Ern
F3 to F4i
Orange----Orange
Blue----Blue
