f3 rectifier problem, not the usual though?
Old Jan 1, 2008 | 03:40 PM
nissan4x4man's Avatar
Default f3 rectifier problem, not the usual though?
I bought a 98 f3. it has 40k. the previous owner had the rectifier connecter melt on him. i bought the bike and replaced it. bike started up fine and then i rode for about 10mins. i was about back to my house and the right side of my bike started pouring out white smoke. i pulled in the driveway and took the side plastic off, the rectifier was dripping black plastic from the inside. i bought one of a 95 that is the exact same but doesnt have the little heat fins on the top, it is just a rubber type cover. i plugged it in and the bike runs great again. i didnt ride it at all just started it and waited to see how hot the rectifier would get. it started getting really hot so i shut the bike off and unhooked it. i am also having a problem whenever i turn the ignition on the headlight fuse blows and the gauge fuse blows when i start going? i am pretty good with mechanical and semi good with electrical so and thoughts would be much appreciated thank you very much!!!
Old Jan 1, 2008 | 05:19 PM
land_warrior.rus's Avatar
Default RE: f3 rectifier problem, not the usual though?
I'd check the stator and all the connectors of charge circuit.
Old Jan 1, 2008 | 05:22 PM
redzintimidator's Avatar
it sounds like your stator is producing too much current...not sure if this is possible of correct...but worth a try.
http://cbrworld.net/forums/thread/140473.aspx
a handy little thing i always keep around
Old Jan 2, 2008 | 07:18 AM
kjohnson's Avatar
This is also typical of when you use a cheap aftermarket r/r.I had an EMGO one blow the 30amp main fuse,and then melt.Not the right way to save 40 bucks. [:@]
c_mo94
Mar 29, 2013 12:42 PM
acdc88
Jul 26, 2009 02:41 AM
36emt37
May 1, 2007 11:53 AM
Kevo
Mar 3, 2007 03:07 AM
bren1422
Sep 9, 2006 07:30 PM
