f3 rectifier problem, not the usual though?
I bought a 98 f3. it has 40k. the previous owner had the rectifier connecter melt on him. i bought the bike and replaced it. bike started up fine and then i rode for about 10mins. i was about back to my house and the right side of my bike started pouring out white smoke. i pulled in the driveway and took the side plastic off, the rectifier was dripping black plastic from the inside. i bought one of a 95 that is the exact same but doesnt have the little heat fins on the top, it is just a rubber type cover. i plugged it in and the bike runs great again. i didnt ride it at all just started it and waited to see how hot the rectifier would get. it started getting really hot so i shut the bike off and unhooked it. i am also having a problem whenever i turn the ignition on the headlight fuse blows and the gauge fuse blows when i start going? i am pretty good with mechanical and semi good with electrical so and thoughts would be much appreciated thank you very much!!!
RE: f3 rectifier problem, not the usual though?
it sounds like your stator is producing too much current...not sure if this is possible of correct...but worth a try.
http://cbrworld.net/forums/thread/140473.aspx
a handy little thing i always keep around
