F3 Radiator does not fit properly?
Old Jan 21, 2023 | 09:29 AM
Halftonmum's Avatar
Default F3 Radiator does not fit properly?
Hey folks, happy new year! I have a very strange problem I've got a little bit sick of as its just not how the bike was intended. My radiator on the f3 has never fit properly, the flanges are far too wide no matter how I try make it fit, its always an inch out on one side, its definitely the right radiator!
Any suggestions? Are they supposed to have spacers?
Old Jan 21, 2023 | 10:12 AM
Do you have item #7 on this fiche?
Old Jan 21, 2023 | 01:23 PM
dannoxyz's Avatar
Yep, each one of those rubbers is 1/2" wide, so 1" total.
These lets you mount radiator without it ever touching frame and breaking off mounting ears from vibration. Radiator only touches rubber.
Old Jan 22, 2023 | 04:43 AM
Halftonmum's Avatar
Hey Ham, yeah those grommets are both on there, do they fasten on the outside on both sides if that makes sense?
Old Jan 22, 2023 | 04:50 AM
Halftonmum's Avatar
Hey Danno, there is still far too much space left on either side! Its really weird how it just doesn't fit, its the second radiator and second frame too and still the same issue, have tried fitting it several times!
Old Jan 22, 2023 | 05:13 AM
Halftonmum's Avatar
This flange I’ve had to bend in slightly to align the bolt just to secure the radiator but not by much
Old Jan 22, 2023 | 03:17 PM
Looks like you have the correct hardware. There should be zero gap though. If you are certain it’s the correct radiator then the only thing left is the mounting brackets are bent. There should be angle on them. The frame brackets should point straight forward and the radiator brackets should point straight backwards.
Old Jan 22, 2023 | 09:34 PM
dannoxyz's Avatar
Radiator bracket in 2nd photo is definitely bent inwards. Probably from crash. Are they removeable from radiator?
I'd remove radiator and measure space between mounting ears. Then bend both brackets on radiator and frame until they line up. Brace radiator bracket so no forces are transmitted to radiator when bending.
Old Jan 25, 2023 | 09:09 AM
Halftonmum's Avatar
Yeah I bent the 2nd bracket just to get a bolt through it and secure it, it’s so odd. Has anyone ever bought one of those new replica radiators from eBay? Thinking of investing as they’re only £100 and mine is absolutely knackered
Old Jan 26, 2023 | 06:16 PM
dannoxyz's Avatar
Possibility they sent you wrong one? Send them measurements and see if they've got one that fits.
Cobretticuz
Mar 24, 2011 02:53 PM
Cobretticuz
Mar 24, 2011 12:05 PM
JMoore84
Sep 13, 2009 02:31 PM
diabloCBR15
Jul 8, 2008 11:19 AM
