F3 Radiator does not fit properly?
Hey folks, happy new year! I have a very strange problem I've got a little bit sick of as its just not how the bike was intended. My radiator on the f3 has never fit properly, the flanges are far too wide no matter how I try make it fit, its always an inch out on one side, its definitely the right radiator!
Any suggestions? Are they supposed to have spacers?
This flange I’ve had to bend in slightly to align the bolt just to secure the radiator but not by much
Looks like you have the correct hardware. There should be zero gap though. If you are certain it’s the correct radiator then the only thing left is the mounting brackets are bent. There should be angle on them. The frame brackets should point straight forward and the radiator brackets should point straight backwards.
The following users liked this post:
Halftonmum (01-25-2023)
Radiator bracket in 2nd photo is definitely bent inwards. Probably from crash. Are they removeable from radiator?
I'd remove radiator and measure space between mounting ears. Then bend both brackets on radiator and frame until they line up. Brace radiator bracket so no forces are transmitted to radiator when bending.
Halftonmum (02-01-2023)
