F3 Fork dampner prob !!
Old Aug 16, 2008 | 07:04 PM
Boffo71's Avatar
Default F3 Fork dampner prob !!
I recently picked up a 98 f3 with bent front end .
To tryand make it simple, i got a used set of forks off ebaythen was planningtoput new sealsfresh oil and install.
When the forks arrived they were totally disassembled not a prob except on the damper rod.
I'm not sure where to set the upper aluminum piece with the preload rings onto the threaded section on the steel rod with the lock nut, I can't find any spec for that in any service manual either.
I usually leave that on when i have rebuilt forks in the past any simple way to set that ?
Thx Chris!!!!!
http://i155.photobucket.com/albums/s...dampnerrod.jpg
Old Aug 18, 2008 | 07:13 AM
kjohnson's Avatar
Default RE: F3 Fork dampner prob !!
Are you referring to the caps that are on the top of the fork?If so,there is no one right way or one wrong way.That adjustment is for you to set where you like it.You gotta play with it some,to find what you like.
20HNDAF4i02
Aug 18, 2009 10:32 PM
chicagoryders
Nov 13, 2007 12:10 AM
ntirorider
Jun 14, 2007 04:44 AM
chainstretcher_ryan
Apr 29, 2005 11:27 AM
