F3 boots
Old Mar 12, 2021 | 08:37 PM
Pvtanderson31b's Avatar
Default F3 boots
Bought some new boots for my f3 off ebay. When I get them on the band screw isnt long enough to reach the square nut. Should I just get longer screws? Also, when I slip them on with the "carb top" side against the carb they kinda flare out at the bottom. Could they be made backwards? Pictures of them sitting both ways
This side should be against the carb but flares out and the open hole is smaller than the opposite side
Flared out
Installed opposite of what its supposed be. Not flared out
Old Mar 12, 2021 | 09:37 PM
Pretty sure these are not the correct ones for your carbs. The screw length is the 1st indicator. There should be ample slack in the screw. Also the bulge your picture shows is incorrect as to fitting. There should be zero bulge. New boots should be snug but require no excessive force to install.
Old Mar 12, 2021 | 10:03 PM
You're right. I figured it out as well. These are mv9 for a f2. Mal is for the f3. Wrong insulator boots
Old Mar 12, 2021 | 10:11 PM
Good deal (that you figured it out, not that you received the wrong boots).
Old Mar 24, 2022 | 11:38 AM
Tr0cZ's Avatar
Sorry I'm bringing this back from the dead but did you ever find new replacements that fit? Seems all of these eBay boots that I'm seeing are MV9 in their picture or their dimensions are smaller than the factory MAL boots. And their descriptions says fits both F2 and F3 - wrong
dyracuse
Dec 31, 2021 12:32 PM
GronkFries
Sep 6, 2018 08:58 AM
sph89
Nov 25, 2009 10:58 AM
sph89
Nov 24, 2009 02:37 PM
SaucyJack
May 21, 2008 09:01 PM
